LabView silent install not working
Hello everybody,
I would like to silent install LabView V21.0 with this commandline: \install.exe /q /acceptlicense yes, but everytime I get this message "The command-line includes one or more obsolete options, Remove /q from the command line"
When I remove the  /q part, the license is not auto-accepted.  In the older versions of LabView I just used setup.exe /q /acceptlicenses yes /r:n without any problems.
Is this a bug in the installerfile?
Thanks,  Michel
(2,386 Views)
Just to make sure, have you tried with "/acceptlicenses yes"? I noticed your first one said license instead of licenses.
(2,347 Views)
Hi Gregory,
Thanks for your reply.
I also tried that, with the same result.
I'm not sure if the commandline is casesensitive thus I also tried /AcceptLicenses yes
So, the final result for now is that I see the licenseagreements screen on my desktop.
(2,335 Views)
Accepted by topic author Michel_71
As LabVIEW 21.0 is a Package Manager-based installer, the command-line parameters have changed. These are now the instructions for silent\unattended installation:
https://www.ni.com/docs/en-US/bundle/package-manager/page/automate-installer.html
(2,313 Views)
Thanks WesW, it's working!
(2,272 Views)
