LabView software for the ADI AD7793
Along with the Evaluations boards for the AD7793 ( a complete analogue front end for high precision measurement applications) a LabView software program was also delivered. Although The LabView software works well, it cannot be  further used in my LabView final application, because it is only an executable.
Does someone out there knows where to find the LabView software or has some experience with this kind of applications?
Because this is for me the first time I’m working with non-NI hardware any help will be appreciated!
thank a lot
regards
Alberto
(3,582 Views)
You will have to contact ADI to see if they are willing to supply you with the source VIs used to create the executable. As far as I know, there is no way to go backwards from a EXE to source VIs.
(3,579 Views)
Thank you nyc for your replay. To my surprise ADI promised to send me the source code!
Regards.
(3,568 Views)
