LabView to grab and save video to mpeg?
Hi Daniel,
In oder to use the filter in LabVIEW it has to be DirectShow compatible. We don't technically support xvid, but I looked into it and found some things that may help.
From the xvid website, it looks like you have to have the DirectX SDK installed, including the DirectShow SDK. If you can get xvid to be DirectShow compatible, you'll be able to use it from LabVIEW:
http://www.xvid.org/FAQ.42.0.html
Another option is to use FFDSHOW, which is like a wrapper for all non-directshow compatible codecs. So you can use the 'ffdshow video encoder' filter option in LabVIEW, then configure the FFDSHOW options externally from the start menu using "VFW configuration" to use whatever codec you like.
http://sourceforge.net/projects/ffdshow/
I hope this helps, have a good day!
Emily C
Message 11 of 13
(1,447 Views)
Dear Emily Thank you very much for your reply. I download the Directshow SDK(March 2009) and installed in the computer but the Labview still can not list the XVID mepg4 fileter in the filter list. I have another problem is that i can not use what you said FF video or Intel Indeo(R) Video R3.2. when i press the SAVE button, the error will be occured. i attached my code and i am not sure whether you can help me to check what's the problem to cause this issue. I want to save the video to the hard disc and hope the file size as small as possbile. thanks Daniel
Message 12 of 13
(1,429 Views)
Hi Daniel,
What error do you see? As I explained before, XVID isn't technically supported. In order to work with LabVIEW, you need to make sure that what you are using is DirectShow compatible.
It may help you to open a new forum post so that more people see it on the front page. It's possible that someone else has done what you're trying to do and will be able to give more exact instructions.
Thank you,
Emily C
Message 13 of 13
(1,415 Views)
