LabView training course selection question
Hello all, I am new to LabView and would like to get training to create programs to read from various sensors (thermocouples, pressure transducers and etc.)
I am wondering how much overlap there is with the LabView Core 1 class and the "Getting Started with LabView" pdf. Is going through and completing the PDF sufficient to start at LabView Core 2?
Also am I correct in assuming that you don't need everything on the "NI Products Used" list; so for example other hardware will be ok to use?
  • LabVIEW 2021 or later
  • NI-DAQmx 21.0 or later
  • NI-488.2 21.0 or later
  • NI VISA 21.0 or later
  • PCI-6221 or USB-6212
  • IEEE 488.2 (GPIB) controller
  • BNC-2120
Link to "Getting Started with Labview" pdf:
Getting Started with LabVIEW - National Instruments (ni.com)
Link to course page:
LabVIEW Core 1 Course Overview - NI
Thank you.
(1,390 Views)
Lessen 1, the correct way to write LabVIEW is LabVIEW. It has been so long since I have taken the entry level training but I would ask why not take both. There may be overlap but at your stage it would be a good thing to go over the material a few times to reinforce the concepts.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(1,346 Views)
