LabView7.0 Eval won't start
I have installed LabView7.0 onto my group's laptop. I don'y have administrative priveliges for the machine so someone else had to actually install the evaluation software while he was logged on. Noe that I am logged on, when I click to start LabView, a window comes up and it appears to be starting and then the program crashes. What could be causing this? Thank you.
(2,919 Views)
You can not run LabVIEW 7.0 and LabVIEW 7.0 Eval on the same machine at the sametime. Uninstall one and it should work.
(2,919 Views)
I'm sorry, I didn't phrase my question correctly. Only LabView 7.0 Eval is in question here. That was installed by the person with administration priveliges and then I tried logging onto the computer to use it and it didn't work. Now it actually works so the issue is resolved, but it only worked after he logged back on and opened LabView himself, closed it, and then I logged on and it finally ran for me. That seems pretty weird to me, but the wonders of PC's never cease to amaze me.
(2,919 Views)
