(LabWindows/CVI 6.0) IVI-C driver for N5770a (Power Supply), header file is missing?
I am using LabWindows/CVI 6.0 environment (Windows XP OS) and needed to download driver for Agilent N5770A Power Supply from NI site. The IVI-C driver for N5770a and other instruments that I downloaded has .c, .chm, .sub, .fp, .txt, and example code files.
I need .c and .h files to run my code. In all of these drivers downloaded an installed, I noticed the header file (.h) is missing. What is going wrong?
The download and installation process runs fine, what should I do to fix it?
(2,861 Views)
You are asking about LabWindows in the LabVIEW board but have you checked the include folder of c:\vxipnp\WinNT? That's where it's supposed to be installed. Or have you done a search for them?
(2,859 Views)
Thanks for your help, found it....
(2,853 Views)
