Label x,y coordinate on plot DIAdem
How do I select and label the x,y coordinate for a min/max point in DIAdem (version 11.0) in the VIEW tab? Is it possible to select a point and have the coordinate automatically labele the (x,y) values? (What if it isn't a specific max or min point?)
(3,600 Views)
Duplicate post and this is the wrong forum.
(3,590 Views)
Not a duplicate, but sorry I wrote it accidentally in LabVIEW instead of the DIAdem forum.
(3,582 Views)
Labeling is best done in the Report panel instead of the View Panel.  Here is a link with information on how to do this. My recommendation for working in the View panel is you could have a Textbox section with a function in the @@   @@ format, such as @@CMax("Channel")@@, but this would not achieve quite the results you are looking for.
Cheers,
Kelly R.
(3,554 Views)
