Labeling data points on a 3D scatter
Is it possible to label data points on a 3D scatter graph? I am trying to analyze some hansen solubility data (3D data that represents relative solubility) and it would be helpful to label each data point so that I know which chemical it represents.
Additionally, once I've got this display where I want it, ideally id want to superimpose a sphere into the space so that some points are enclosed while others are included. Is this possible on a single graph?
I've attached the simple VI I have so far.
Thanks!
(3,894 Views)
Hi NGKai,
I did some research and I try some test by my own and as far I know there is no way to label data points on a 3D scatter graph, that is why the graph has the color scale on it.
Acording to the other question "deally id want to superimpose a sphere into the space so that some points are enclosed while others are included." there is a way to do it and is creating a multiple 3D plots in the same graph, please take a look into this files:
Create Multiple 3-D Plots
https://forums.ni.com/t5/Example-Code/Create-Multiple-3-D-Plots/ta-p/3527963
How Do I Create Multiple Plots on a Single 3-D Graph in LabVIEW?
http://digital.ni.com/public.nsf/allkb/0ABACC8B023C15D3862572ED0070E4A6
I hope this info works for you!
Regards
(3,590 Views)
