11-10-2006 01:48 PM
11-10-2006 02:06 PM
Hay Ted,
I tried out your scenario and I have the same thing happen. If all else fails, you could make fake labels, or you could make a seperate display that is programatically connected to the chart. But I programatically managed to make the labels show. I have it attached. You will input the name of the VI that contains the chart (make sure it is in edit mode), then press "Show Labels", which will show them. Then, you can edit them. You can also hide them, but remember you can only do this programatically. The program is unlocked so you can see what I did. The program was made into LabVIEW 7.0. Hope it works!
Actually, I'll send another message when it is finished. Sorry! Expect it in about an hour.
7J1L1M
11-10-2006 02:56 PM - edited 11-10-2006 02:56 PM
Message Edited by 7J1L1M on 11-10-2006 02:56 PM
11-10-2006 02:59 PM
11-10-2006 03:07 PM
Your welcome (I didn't know I could make programs in 20 minutes!). By the way, I realized I had a bug. So here is the fix (it is saved in LabVIEW 7.0).
7J1L1M
