Labvew is not recognizing the .iak file
hi-
I am trying to execute my program in labview, using my cFP-2020.  However, it will not recognize my .iak file.  When I go to view configuration, it is listed with the correct file path but will not go to the file.  It is giving me an error message 32812.  I have tried moving the .iak file to a different location and no change.  When I execute the program in my RT target, it works fine.  Also, everything in MAX works fine.  I am using LabView 7.1 with the simple FP write vi.  I read through the other posts and could not find anything that would fix the problem.
Curt
(2,495 Views)
Hi Curt,
Try creating a new .iak file within Measurement and Automation Explorer (MAX) and referencing it instead.  Now does a simple program with FP Write work?  If so, refer to the knowledgebase article titled Error 32812 From FieldPoint VIs for more information (situation 5).  If not, please post back and we will continue to troubleshoot.
(2,472 Views)
