Labview 2009 get hangs on client computers when Labview 2k9 is started on Server
I have three computers. On one Computer Windows 2003 server is installed.
and on other two computers windows XP Pro is installed.
Labview 2009 is installed on all three computers.
Labview VIs are stored in a shared folder on Server Computer.
The client computer open and Run VIs stored on Server Computer
BUT as soon as, I start Labview on Server Computer, Labview VIs on Client Computers
(accessed from Server) get hangs. and when I close Labview on Server then those Programs
start normal navigation .
Mean while following event is logged in event viewer durin hanging:
Labview information : Error: 400 Bad request for file ,"""", BAd HTTP request
Event ID: 3299
(3,270 Views)
Some additional information would be helpful here. It seems as though there is a conflict being caused by the server where the VIs are loaded into memory and not released.
1. Are you running Windows Server 2003 R2?
2. Are you running LabVIEW 2009 SP1 on all computers?
3. Can you clarify that opening and running one of the VIs on both client computers at the same time does not cause an issue?
-Zach
(3,239 Views)
