Labview 2009 install on windows 7 fails with error code 1935
Hello all,
I have problems installing LV9 on my windows7 machine.
It always ends with:
Any ideas would be welcome.
Albert
(5,502 Views)
Do a search on the forums for "1935".  The common theme seems to be it is related to .Net frameworks and that they may need to be updated.
(5,489 Views)
Since it is not simple to reinstall only .net framework on W7  (it is part of the operating system),
I checked the .net framework with the .NET FRAMEWORK VERIFICATION TOOL
http://blogs.msdn.com/astebner/pages/8999004.aspx.)
Verification succeeded for .net 2.0,3.0 and 3.5.
Since there are more problems on this pc. (1:windows update problems with strange errorcodes, 2:unable to turn windows features on/of)
i decided to rerun the W7 setup.
i selected the upgrade option , assuming this would update corrupted files, and it did.
After that LV9 installed without problems.
Albert
(5,455 Views)
