Labview 2010 64 bit?
Hi everybody,
I want to know at how many bits the new Labview 2010 program works.
Is it possible to select if it works for a 32 bit or 64 system, or does it switch by itself to this mode?
I hope that someone can tell me more about it.
Kenny
(3,331 Views)
There is 2010 LabVIEW 32 bit and there is 2010 LabVIEW 64 bit. You can install both if you like if you have a 64 bit OS.
Unless you need the massive 64 bit address space (and you probably don't!), I would recommend you install LabVIEW 32 bit, because it is more universal and has better support for addons, drivers, and modules. Not all are available in 64 bit.
LabVIEW 32 bit works perfectly on a 64 bit OS.
See also:
LabVIEW 64-Bit vs. 32-Bit Applications FAQ
(3,318 Views)
