Labview 2010 activex container Excel 2007
Hello All,
How do you get LabVIEW 2010 64bit, Windows 7, Excel 2007 to appear in a container?  When I try to insert an activex object in a container excel is nowhere to be seen.  I have already gone into excel Trust Center and enabled all controls which did not work.
Karl
(5,382 Views)
Excel doesn't have an ActiveX control. It has an ActiveX interface allowing you to programmatically open/create workbooks, but no visual control.
There is a separate Microsoft Spreadsheet control, but that does not read/write Excel workbooks. As noted in my response in the link I provided you could also use a browser ActiveX control to embed an Excel spreadsheet. This would be the same as embedding an Excel spreadsheet in, say, Internet Explorer.
(5,379 Views)
Using an activeX control is exactly how I used to do this.  The link to the examples in the post do not work on a XP windows machine, Office 2007 and LV 2010.  Have you tried to do this lately?
(5,287 Views)
I am also having the same problem. I am using LabVIEW 2010 32 bit and Microsoft Office 2007 and I cannot see spreadsheet control under ActiveX container.
(5,104 Views)
That's because the spreadsheet control is not part of Office 2007. It's a separate component that is part of the Office Web Components. Microsoft discontinued these with Office 2007. You can download them separately from Microsoft's web site. Note: the spreadsheet control is NOT an Excel ActiveX control. It's a completely different beast.
(5,093 Views)
