Labview 2010 crash at startup windows 7
Labview crashes on startup. I get this message: "Labview 10.0 Development System has stopped working." I don't get any further than this.
I have 95 computers running Windows 7 64-bit Enterprise. To install Labview on these I use the automated installer with these options: "/q /acceptlicenses yes /r:n /applyspecfile k:\zfdmsi\Labview2010\yellow1\".
This was working on Windows XP. I have tried to install Labview manually on one of the windows 7 computers and it works fine.. But I cant do that on 95 computers...
Any ideas why it's crashing?
Thanks in advance.
(3,214 Views)
I tried again installing with CD's on a new computer today and I get this message: "Error: This installer needs access to "My Documents". However, this location "m:\HiTfiler\My Documents\" is not available. Ensure that this directory exists and is available and run the installer again."
This path does exist though.
(3,187 Views)
You have the drive letter listed as "m".  Is that correct?
Is that a network drive?  Sometimes trying to establish connections with network drives are more time consuming then it would be a local hard drive, and the installer is not getting a response from the M drive in time.
(3,178 Views)
Accepted by topic author Venruki
Yes, m: is a network drive. We have a local policy on all workstations redirecting My Documents to the M: drive.
I got the issue resolved by installing Labview 2010 SP1 🙂
(3,165 Views)
