Labview 2011 Won't load !! :(
I just downloaded Labview 2011 and installed it.
The install process worked just fine.
After I rebooted my PC I clicked on labview and it wasn't coming up.
The CPU was at 100% on one core
I looked in the task manager and saw labview.exe*32 at the top of the list hogging my CPU but no Labview windows.
I thought it was possibly just taking a little while but after 5 min to 10 min I lost patience and killed the process.
PC Config:
MS Windows 7 64-bit SP1
AMD FX(tm)-6100 Six-Core Processor
Gigabyte Technology Co., Ltd. GA-990FXA-UD7 (Socket M2) Motherboard
Any Ideas???
Glenn Ellis
Message 1 of 15
(6,124 Views)
It sounds like something has currupted during your installation.  LabVIEW 2011 supports Windows 7 x64 and your hardware should not be an issue.  I would try uninstalling from "Add/Remove Programs" and reinstall - usually does the trick Smiley Happy
Peter D
Message 2 of 15
(6,101 Views)
Thanks for the replay.
I did uninstall it.
Redownloaded it from both the website and ftp (ftp.ni.com/support/softlib/labview/labview_development_system/2011)
and installed it.
Could the download be currupt?
Glenn Ellis
Message 3 of 15
(6,089 Views)
BTW this is happening on two different computers Smiley Mad
Glenn Ellis
Message 4 of 15
(6,054 Views)
Do you run any personal firewall or other security software?
Message 5 of 15
(6,049 Views)
If got the same Problem?!?!? Same PC Configuration as Glennjammin. Any Solutions?
Lg
Message 6 of 15
(5,982 Views)
Hello everyone,
we were able to help C.Schmitt today and will follow up as soon as possible.
Best regards
Marian Vorderer
Message 7 of 15
(5,965 Views)
@MArian Olef wrote:
... and will follow up as soon as possible.
Please do!
Message 8 of 15
(5,911 Views)
Hello Christian,
sorry, but I am not able, to provide more details at the moment. We were able to solve the issue at C.Schmitt's site, but I have to do some investigation at his site. If you have the same problem / specific questions, do not hesitate to write me a PN.
Best regards from Central Germany
Marian Vorderer
Message 9 of 15
(5,896 Views)
Are you able to launch LabVIEW if you right-click and select 'Run as administrator'?
Message 10 of 15
(5,889 Views)
