Labview 2011 write2D array to spreadsheet file
Today I tried to write 2D array to a file with the "write to spreadsheet file" function with the newest LabVIEW 2011(f2).
But it generates the following results - all data in one column (supposed to be 2 column) .
LV2011
WT
(3,866 Views)
Edit: Nevermind - I saw you added the VIs while I was posting..
I just looked at your code. It is writing both columns.
LabVIEW 2012
(3,859 Views)
Accepted by topic author weitong
Hi weitong,
Excel defaults to expect semicolon as delimiter in csv files. Change your tab constant to a semicolon and all is fine...
Or open to file using the import dialog of Excel and set tabs as delimiter in step 1 of that wizard.
(3,852 Views)
What do you mean?
(3,849 Views)
I got it.
Thank you very much!
(3,843 Views)
You are not saying what extension you gave to the file. Excel can handle tab delimited tables easily, just give them a *.txt extension.
(using comma delimited (*.csv) is a can of worms, because the comma is also used a decimal seperator in some countries where other delimiters need to be used.)
Also note that if you build the array inside the loop, you don't need to transpose.
(3,834 Views)
