Labview 2012 SP1 f5 halting on Win 6 x64
I am using the latest Labview 2012 x64 SP1 with f5 update and am finding that it halts and forces me to close labview and restart. Anyone else having the issue or knows what might be causing the issue?
(2,741 Views)
Sorry Win 7 x64 bit.
(2,726 Views)
Just to be clear, is it restarting LabVIEW or your computer?
Also have you tried restarting your computer because if you just installed the patch you would need to restart your computer.
Paolo F.
(2,695 Views)
I regularly get 2012 SP1 f5 shut-downs but these tend to only occur when I am working on a project with a nested LVOOP hierachy and I'm making changes to that hierachy.
I don't know what activities you are doing that cause the re-start but it might help to know what you are working on when it happens; or post your LV internal error report to NI (I assume NIER is doing it's job).
(2,690 Views)
Paolo it is re-starting Labview and it is occuring multiple times per day. TYK007 I am not doing LVOOp or anything special or even that large. I have let it send the error reports in. I happens about half dozen times or so a day since I installed 2012 SP1 F5 patch.
(2,681 Views)
