Labview 2013 + Windows7, can't add file to llb
Very simple, I am trying to add VI file to LLB but instead of that Labview is trying to save VI file as LLB.
New feature of LV2013?  LLB's are not displaying as folders anymore? Bug?
Message 1 of 17
(3,854 Views)
to add a file to an LLB, select File»Save to save the file in a new or existing LLB.
Message 2 of 17
(3,840 Views)
Note : You cannot undo changes you make using the LLB Manager window.
Message 3 of 17
(3,835 Views)
Thank you for your readiness to help,
this is exactly what I have been doing on earlier versions of Labview for 15 years or so but it doesn't work on my current 2013 version.
This becomes really annoying when I can't do any simple action with Labview without wild shaman dance with tambourine.
Message 4 of 17
(3,834 Views)
what is about converting the LLBs to and from directories ? You can add your VI to the directory and convert it back the llb
Message 5 of 17
(3,829 Views)
Try to open the LLB Manager window and then drag and drop your new VI into the existing llb. The VI and the llb file should be in the same directory.
Does this work?
Message 6 of 17
(3,823 Views)
This is what I call "shaman dance with tambourine". Smiley Very Happy
Message 7 of 17
(3,819 Views)
Does this work?
Nope
Message 8 of 17
(3,819 Views)
In old times I remember Windows were able to handle LLB files as folders, but my Windows7 can't.
Message 9 of 17
(3,808 Views)
Could you possibly add the LLB file and the VI to a project? Then drag the VI in the project into the LLB and save the LLB.
Kind Regards,
Larry Colvin
Associate Principal Engineer
Dyson Technology Ltd.
Message 10 of 17
(3,771 Views)
