Labview 2013 are closing when I try read table from database.
I don't get error message, Labview just crashes. I'm use Labview x32 and Database Connectivity Toolkit connective on Windows 7 x64. I connect to PostgreSQL with ODBC driver, connection is stable.
In my database I have many tables, I can read all them without one.
When I try read bad table I get data and then labview crash. When I restart Labview I don't have any message about error.
Also I try use LabSQL-1.1a. But it has same result.
(3,756 Views)
When LabVIEW crashes it generates a Error Log File, can you post this file to see what's going on?
This article shows where to find the error log file.
Chris S.
(3,725 Views)
Try connecting using UDL file. What operation you are doing with database
You can create the same.. Do this Tools --> Create Data link..
Then go to http://www.ni.com/pdf/manuals/371525a.pdf link and see page 3-5. It will help
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,719 Views)
I didn't have error message or crash message. Labview just closed and when I start Labview again I don't have any message about saving an error log the previous time. It's like I simple close Labview and start again.
(3,711 Views)
Close only application or complete LV closes?
Try using udl file as suggested
--Ranjeet
(3,708 Views)
Complete LV closes
(3,704 Views)
Accepted by topic author slavadubrov
I found the solution.
I think problem was that I have very big array in my database.
Early I got data from table with next quiry:
SELECT column1, column2  FROM "table";
But when I write next:
SELECT column1, array_to_string(column2,',') FROM "table";
all worked!
(3,698 Views)
