Labview 2013 crashes when "startScreensaver.exe" starts on Windows 8.1
Ok from what I can tell this isn't a default program that comes with Windows. If you know you downloaded it then all I can say is that it appears there is a compatibility issue. If you aren't aware of where it came from I would recommend uninstalling and removing it since Windows already has a screen saver.
Jonathan L.
Technical Support Section Manager
Message 11 of 16
(819 Views)
I too am seeing LabVIEW 2013 (32bit) crashing on my computer, after installing Windows 8.1.  I'm not running any vi,s, just launching LabVIEW.  Are there any known workarounds?
Message 12 of 16
(800 Views)
That seems like a very differenet problem, unrelated to the existing discussions. you should start a new thread.
Did you have LabVIEW already installed and then upgraded the OS to 8.1? What was the previous OS (Windows 7, Windows 8.0, etc.?)
Message 13 of 16
(797 Views)
LabVIEW was already installed.  Should I start a new thread, or is there another for this issue?  I can't imagine I'm the only one with thtisproblem, but this was the only thread I found in my serch.
Message 14 of 16
(793 Views)
It is always better to start a new thread, this way you can mark the solution if available. In the current tread, LabVIEW crashes at the screensaver, not when opening LabVIEW.
Have you tried repairing the LabVIEW installation?
You still did not say what the previous OS was. (Personally, I had no problem with LabVIEW when windows 8 upgraded to windows 8.1.)
Message 15 of 16
(787 Views)
OK, good to hear.  I did go from 8 to 8.1 as well.  I will repair, and if I still have trouble, I'll start a new thread.
Message 16 of 16
(778 Views)
