Labview 2013 slow after building application
I have Labview 2013 with the DSC module installed.
I am running on Windows -64bit with 4 GB RAM
After I build my application, Labview slows to a crawl.  There are no errors when I create my application and my application runs fine
All other programs run fine.
The windows task manager shows CPU use ranging from 2 to 20%
I have to shut down the computer and restart it.  Then Labview is again running fine.  Until I build my application again.
My application was originally developed in Labview 2012
I have not yet tried to create a new application to see if it is specific to my application or my Labview setup.  I will try that next but I wanted to see if anyone else had this issue.
(3,171 Views)
Is this Windows 8, 7, Vista, etc?
Are you running 32-bit LabVIEW or 64-bit?
I would definitely recommend seeing if this problem happens when you try to build any application, or just your specific application?
Assuming the problem only occurs with your specific application, I would recommend that you try to build it on a different machine (assuming you have access to one) and see if LabVIEW behaves the same way on that other machine.
When you originally built your application in LabVIEW 2012, did you encounter this problem?
You could also try repairing both LabVIEW and the DSC Module to see if that makes a difference.
Ryan K.
Product Manager, ATCA and BEEcube
(3,114 Views)
Are you talking about execution speed or general (non)responsiveness in edit mode?
(3,103 Views)
Non responsive in the edit mode.  I click on a menu item and wait 10 seconds for the menu to appear
 - I am using windows 7 64 bit
- Labview 32 bit
I did not have this problem when I used version 2012.  I have not tried repairing labview or the DSC.
(3,097 Views)
Were you able to test if building an application from a new project causes the same slow down? Have you tried performing a mass compile to make sure all the files in the project have been upconverted to 2013?
Taylor B.
(3,048 Views)
