Labview 2014 Excel Active X Property Nodes disabled - Why?
I am using Labview 2014 and want to open, write to and close Excel by the use of Active X.
I am confronted with the problem, that, if connecting (Active X-) property nodes to the references (e.g. "Excel_Application"), right-clicking on the context menue doesn´t let me choose any properties, the item is disabled (one can read in German "Keine Eigenschaften" (no properties)).
How can I resolve this? What am I doing wrong?
Thank you!
(3,076 Views)
i would like yo understand more of your problem. can you elaborate more? maybe provide some screenshots of your code to see what are you trying to do as a whole?
regards,
Sigi D.
AE
"everything is achieveable through technology'
(3,056 Views)
I am having the same problem.  When I left click to choose/change the property I do not get a list - instead I get the greyed No Properties popup - see screenshot.
If I drag and drop an existing property node from within an example subVI it connects to the reference and keeps showing the current property but I cannot change to a different one.
I am using LV 2012, Win7, Office 2013.
When I try with LV 2012, Win7, Office 2010, it works properly.  So my guess is that is has to do with the version of office.  But I would like to know the reason why as well.
(2,902 Views)
