Labview 2016 LLB Source Distribution
Tried it out.   Nope folders to old smashes folders to llbs unless they contain extensions like llb.
Cut n paste won't paste to anything other than another llb
Message 11 of 18
(2,113 Views)
Thanks for your suggestions thus far, (christineb/altenbach/Jeff Bohler)
 Yes, LLB's was made for the long filename fix, back in the day. No other real reason. I see where the "known path" might work,like <LabVIEW>\Userlib\Groupxxx\LLBNAME\, but that doesn't give me a reason to keep the LLB. Will go the LV project route. I'll run a few LLB's through it,check out auto-pop
Historical Side Note: Does this imply LV under Linux or Mac had no real need for the LLB since those OS's didn't have long filename limitations?
Message 12 of 18
(2,103 Views)
Having "something" that could wrap several functions in a single file was useful in itself.  An LLB was the only option before lvlibP ppls .  But they had drawbacks...
Message 13 of 18
(2,094 Views)
Hi Jeff,
Just tried myself with LV2018:
- made a LLB with 3 VIs
- opened the LLB with the manager
- selected all 3 VIs within, right-click, copy
- moved to a "normal" folder within the LLB manager
- clicked on "paste" icon in the menu line: all 3 VIs are copied into the folder
Still works as has been for years…
Message 14 of 18
(2,090 Views)
@GerdW wrote:
Hi Jeff,
I'll be a monkeys uncle.  I never knew an llb could have a real folder...I'm pretty sure 5.1 and 6 didn't allow it so... We all stopped using LLBs
Turned out to be easier back then to save as, rename in windows explorer then manually replace subvis using the hierarchy view than deal with LLBs.
I probably should have investigated more when the llb manager was introduced!  I might have still been trying to figure out how to permanently disable Auto Tool at the time though...:D
Message 15 of 18
(2,082 Views)
HiJeff,
I never knew an llb could have a real folder…
You cannot have a folder within a LLB. But you can navigate to a folder on your disc within the "LLB Manager"!
Select and copy the files within the LLB using the LLBManager, paste the files to a real folder using the LLBManager. That's how I turned every LLB I had into real folders…
Message 16 of 18
(2,078 Views)
Hi Folks,
 Let me chime back in here.
Short answer - Yes.
Long Answer-
The LLB Manager allows you to see everything inside and outside of the LLB itself. Just open another LLB Manager, be sure you "know where it is" from the "URL window" (not its real name).
Then go copy/paste/move just like in Windows Explorer
What I am still trying to do Labview source distribution (of Directories and/or LLB's) is allow the "package" of vi's to be called by whatever Top-Level vi is in that same package--no matter where that "package" is moved to. At the risk of sounding too simplistic- what Labview Source Distribution does now is akin to "absolute addressing" and what I am looking for is akin to "relative addressing". Maybe there's a way to achieve this, Mongo don't know. For now we here (there's four of us at present) have a work-around.
Thanks for your help thus far
Mike
Message 17 of 18
(2,073 Views)
Ah,  That a pkg!  NIPM / VIPM create those
Message 18 of 18
(2,068 Views)
