Labview 2017 - Centos 7
RTSLVU wrote:
LabVIEW still looks more modern than Windows 8 and 10 with their "tiles", flat color scheme, and 90 degree square corners.
I think the Aero theme (Vista Windows7) is the most modern looking GUI.
Doesn't LabVIEW's welcome screen have a scrolling message with a link extolling the virtues of a flat UI?
"Evolving UI is more than just skeuomorphic to flat"?
https://forums.ni.com/t5/LabVIEW-News/Evolving-UI-Technology-Is-More-Than-Just-Skeuomorphic-to-Flat/...
Found a link whilst checking spelling.
GCentral
Message 21 of 28
(2,175 Views)
Why would you think that changing LabVIEW version will change anything in respect to something which is in fact a system problem, that prevents VISA from accessing the serial port?
Or is this something else that doesn't work?
"It still doesn't work!" is a very imprecise error description.
Rolf Kalbermatter  My Blog
Message 22 of 28
(2,173 Views)
Because we aren't  sure about labview 2017 is a final version.
Ok, so now I have open visa ok!   ----> write visa is fine.....when i try to read I have a timeout.
Message 23 of 28
(2,167 Views)
This is actually most often caused by the use of no or the wrong termination character in the command you write. Your device is not processing the command until it sees the desired termination character and therefore won't send any response.
Instead of trying to configure VISA to append that character automatically you should simply add it yourself to the string you connect to the VISA Write. If you use the VISA Configure Serial Port (Instr).vi to initialize the serial port make sure that Enable Termination Char (T) is set to True however and the termination char has the right ASCII character code connected to it, so that VISA Read will terminate when receiving this specific character.
Message 24 of 28
(2,159 Views)
@RTSLVU wrote:
@Muri777 wrote:
Side note but when will the LabVIEW UI become prettier? Will we ever see vector graphics or an update to the way it looks? It still looks old and outdated...
Actually I disagree - I think the direction that modernism is heading is favouring simplicity - less is more. Applies to almost everything now (cars, buildings, rooms, graphics designs etc)
I think vista was the worst of the kind - too bubbly and over the top. Windows 10 sits nicely now. Simple, easy to see and no ott flashy things. MacOSX also looks really nice.
Message 25 of 28
(2,150 Views)
We have all this fancy video hardware and we're being forced to look at CGA graphics.
Bill
CLD
(Mid-Level minion.)
Message 26 of 28
(2,137 Views)
I think computer OS's aren't meant to chew up GPU resources Smiley Very Happy
Message 27 of 28
(2,132 Views)
That's why I think .Net is still a bad idea to use in an application. And even worse to add it to an environment like LabVIEW. Smiley Wink
Message 28 of 28
(2,128 Views)
