07-06-2018 02:33 AM
I use labview to control the AFG3252 from tektronix. Sometime it's work very fine. But the software seems not very stable. The AFG3252 can't be query suddenly. But I can control it form Tek-Visa. So it seems the VISA interface from Labview to the instrument have some problem. How to find the reason of this issue.?2018-07-06 15_32_30-Tektronix AFG 3000 Series.lvlib_Initialize.vi Block Diagram on Transducer_TB.lvp.png
The error message is below:
The ID Query failed. This may mean that you selected the wrong instrument or your instrument did not respond. You may also be using a model that is not officially supported by this driver. If you are sure that you have selected the correct instrument and it is responding, try disabling the ID Query.
07-06-2018 07:14 AM
Does your *IDN? query require a termination character at the end of it such as a line feed or carriage return? Did you include that character in the command?
(Turn on \codes display for the constant so you can see if it is there.)
