Labview 2017 x64 & MySQL .NET Connector
Good Morning all,
Up until now I have been using Labview 32bit with the Database Connectivity Toolkit for 70% of my applications. Unfortunately the Database Toolkit is not supported under Labview 64bit so I`m looking for alternative methods of connection. (.NET seems the best option so far)
Can anyone help me with the implementation of the .NET connector in National Instruments Labview.
I`m trying to set up a simple VI to which I can pass an SQL statement and, depending on that statement, return a string array of data or a confirmation.
So far i`ve not had any luck using the .NET connector for this. Below is the sequence from my attempt so far; (dataSet is created using System.Data.DataSet(String dataSetName)
Constructor - MySQLConnection,
Property Node - MySQLConnection(ConnectionString),
Property Node - MySQLConnection(OpenAsync),
Property Node - SqlDataAdaptor(SelectCommandText,SelectConnectionString),
Property Node - SqlDataAdaptor(Fill,dataSet)
I`m not sure what I should do next to read the data? Should I use MySQLCommand.ExecuteReader ? I`m guessing I would also need to use .NetObject to Variant and then Variant to Data?
Any help would be greatly received, ( I know the error lines aren't connected yet ....
Nick
(3,977 Views)
I have found it easiest to translate VB.NET code to LabVIEW.
https://dev.mysql.com/doc/connector-odbc/en/connector-odbc-examples-programming-net-vb.html
(3,944 Views)
Hi nyc,
Thank you for that info, i`ll have a look through and try to convert to MySQL .NET connector commands.
Nick
(3,930 Views)
Just to complete this thread for everyone coming across it newly: You can find a potential answer here: .NET Dataset for LabVIEW 64-bit (without LabVIEW Database Connectivity Toolkit)
Ingo – LabVIEW 2013, 2014, 2015, 2016, 2017, 2018, NXG 2.0, 2.1, 3.0
CLADMSD
(3,900 Views)
