Labview 2018, Python, x64
Labview 2018 support Python https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/menus/categories/computer/python-node-mnu....
In https://www.ni.com/en/support/documentation/supplemental/18/installing-python-for-calling-python-cod... is written, python36.dll is used.
I have Miniconda 3.6 x64 installed.
If Labview call python36.dll  direct (not via network), I need Labview 2018 x64?
Up to now I used Labview 32bit, because not all Toolkits are available for x64: https://www.ni.com/en/shop/software-portfolio/national-instruments-product-compatibility-for-microso...
But this document is no up to date, the LabVIEW Advanced Signal Processing Toolkit support now 64-bit, https://www.ni.com/pdf/manuals/375335d.html#64bit
Peter
(8,793 Views)
Accepted by topic author Peter_S
Yes! A 64-bit DLL can only be loaded by a 64-bit process! That's a Windows limitation and can not be worked around by a process without writing a huge amount of thunking code.
Rolf Kalbermatter  My Blog
(8,750 Views)
we can find the LabVIEW 2018 offline trial version and legal download link from this website.
I downloaded but that not support windows xp, why? what is the problem?.
Admin note - removed hyperlink to suspicious website
(8,476 Views)
Windows XP came out 17 years ago and is not supported by recent versions of LabVIEW. This document details which Windows versions are supported by which LabVIEW versions. The last version that supported Windows XP (SP3) was LabVIEW 2015.
For security you should really download trial versions directly from National Instruments instead of third-party download sites. Try this link: https://www.ni.com/en/support/downloads/software-products/download.labview.html
(8,471 Views)
That website is so full of errors it is almost laughable!
I'd definitely steer clear of it, who knows what you are really downloading.
-AK2DM
(8,452 Views)
Aside that most of those download sites don't do that out of charity but to earn some money, and providing manipulated downloads with nasty payload is one pretty common way to monetize the download service, I also think that they skate on very thin ice legally even if they wouldn't resort to such practices. The software is copyrighted and NI definitely never gave them the right to provide it for download.
(8,434 Views)
There is another wrinkle to be aware of, at least if you are using Miniconda 3 and possibly in other distributions of Python and 64bit LabVIEW on Windows at least (and possible 32 bit, but I haven't tested).
Python 3.6.7 and 3.6.8 both fail to load properly and return an error 1671 in Open Python Session. Earlier versions work ok.
Note this is specific to the Python version installed via conda and is nothing to do with scripts stored on network drives, python36.dll not being in the path etc, it is purely triggered by doing:
conda install python=3.6.7
and fixed by doing:
conda install python=3.6.6
Not at all clear what the change is that has broken things and whether to shout at Continuum or NI...
Gavin Burnell
Condensed Matter Physics Group, University of Leeds, UK
http://www.stoner.leeds.ac.uk/
(7,833 Views)
