Labview 2024.1 FP.Monitor property node and Windows 11
Hi all,
I use the property node FP.Monitor to lock a panel to a specific monitor. However since I updated to Win 11 the actual monitor it locks to changes depending on its "mood". Sometimes the three monitors are 0,1,2. Sometimes 1,2,3. Win10 always set the monitors correctly.
Is this a Win 11 bug (like many) or is there a fix say using another method.
Many thanks
Jessica
(394 Views)
You could consider using .NET to get monitor information instead of LabVIEW, which might behave differently... I don't have Win11 to check.
I made a post about using .NET for this quite a while back, it and the thread it's in might be something you can refer to, even though it's about size:
https://forums.ni.com/t5/LabVIEW/Get-Usable-Monitor-Size/m-p/3223205#M936555
(364 Views)
