Labview 3.1 from Mac to PC
who is experienced in switching Labview 3.1 applications from MacIntosh to PC
WIN 9.x/NT based LabView 5.0?
Who knows all about the different filetypes (type & creator used by Mac) and
the right translation for PC fileformat (filename in 8.3 convention, means
"filename.ext")
Thanks for any help, Rolf
(2,969 Views)
Hey Ron,
LabVIEW is a platform independent environment, so you should have no problems
porting your MAC VI's to Windows. However, I found a Knowledge Base article that
may help you. I went to NI's homepage (www.ni.com) and typed "transfer between
platforms" and only searched the support pages. The first hit should
help you.
I hope this helps,
Kevin
Rolf Lindenau wrote:
> Hi,
> "filename.ext")
(2,969 Views)
Using 'TransMac', the creator is *LBVW*, the types are *LWVI* for VIs, and LVAR for LLBs. I don't know for 'shared llb'.
Strings between ** may not be accurate; however TransMac shows both of them, and they're close !
I used the demo version of this software, tht is limited to a filesize up to 1.4 Mb.
Serge
(2,968 Views)
