Labview 3.x and Y2K
We've got an old Labview 3.1 system that we use infrequently to log
experimental data. The NI web site indicates that Labview 3.X and below
"Will Not Be Tested" for Y2K compliance.
Does anybody know what sort of problems we may have next year when we try to
run our application?
(3,490 Views)
LV3.1 really doesn't do much with time formatting or
other routines that might cause problems. On the
other hand, it was compiled and linked to libraries
about five years ago. I don't believe there was any
Y2K information for the versions of the compiler and
libraries that it was built with.
The OS you are running on will also have a big impact.
Win3.1 is far from Y2K compliant, and older revs of
other OSes have some problems as well. I believe that
the NI Y2K site lists the te
sts that were used to
determine correct behavior. If you would like to
test your OS/LV combination, then follow the steps
on the web site.
Hopefully, you will not have any problems with the
product, but if you ever need to reinstall it that
may be troublesome too since it used installers
from five years ago, and installers do creation and
modification date tests along with version checks.
Again, the installers were licensed off the shelf,
but I don't believe they are Y2K friendly.
Before someone jumps on my case, these tests were
done for lots of versions and combinations of LV.
We decided that it wasn't worth it to go all the
way back to LV1 on Fat Macs or other antique versions
of LV. We made our test recipe available on the
web site in case someone needs it.
Greg McKaskle
(3,490 Views)
Thanks for the detailed info and the pointer to the list of Y2K tests.
We'll probably upgrade the system that LV 3.1 is on to Win98 and upgrading
LV to the latest version is also an option.
Are there any gotchas in trying to run a LV 3.1 app on LV 5.1?
The app is pretty simple - data logging only, no control functions.
Greg McKaskle wrote in message
news:38054343.FCE98D7B@austin.rr.com...
try to
> the NI Y2K site lists the tests that were used to
> on the web site.
> Greg McKaskle
(3,490 Views)
I wouldn't expect there to be any problems, or at least not any that are
difficult to resolve. You can get a demo copy of LV5.1 and try it out
first if you would help.
Greg McKaskle
(3,490 Views)
