Labview 32Bit running on 64Bit causing issues with connecting to database
Hi All.
Ok, Windows 7, LV 32Bit Profesional installed.
Wampsever latest
ODBC latest installed
ODBC Latest
Created a Database (MySQL) within PHPMYADMIN. using a DSN name trying to view all of the fields in the table, I get teh following error.
1st - it was mis match in architecture, (so I upgraded to all teh latest versions) now I get teh following:
Exception occured in Microsoft OLE DB Provider for ODBC Drivers: [Microsoft][ODBC Microsoft Access Driver] The Microsoft Jet database engine cannot find the input table or query 'James'.  Make sure it exists and that its name is spelled correctly. in ADO Connection Execute.vi->SQL Execute.vi->GetSQLTable.vi->Send&RecieveSQL.vi
I am trying to run the ODBC from the 64 bit file version. But still no joy...................
Any ideas would help loads.
James
(3,389 Views)
Hi James,
Here is what Microsoft has to say on the issue in Access. I hope it proves helpful.
http://support.microsoft.com/kb/287696
I will let you know if I find aynthing else specific to ODBC.
Rhys
(3,332 Views)
Are you using the right driver?  "ODBC Microsoft Access Driver" wouldn't be my first choice to connect to a MySQL database, though it might work.
Are you configuring your connection in the ODBC Data Source Administrator?  Do other reads or writes to the database work?
(3,305 Views)
I Have actually moved on to a 32Bit machine - due to teh headaches that have been caused.
The ODBC connection was correct - and this was able to connect to the Database created. The last problem faced was teh JET 4.0 issue which looking into is also tied down to a 64Bit platform issue.
If there is another connection prgram that would work Ia m happy to try that.
James
(3,281 Views)
