Labview 5.1, I don't succeed to print a report (error 41002) using the full printer path name. Could you provide me examples? Thanks
I already tried the tips given by the Document ID: 1VNE8JR5, but without any success.
When I don't provide a printer name (or path), the Report is printed on the default printer. This printing works fine under Win98, but it doesn't work on WinNT or WinXP.
(2,828 Views)
Denis,
I ran the Text Report example on to a network printer on a Windows 2000 machine by typing "\\tempest\ae01", our 2nd printer in the Applications Engineering department, and the report printed fine. What are you using for a remote printer name?
Randy Hoskin
http://www.ni.com/ask
(2,828 Views)
Hello Randy,
Thank you for your answer.
The printer name is "R&DHP4000TN" and the printer server name is: "SERVEUR_BDC".
So I think the full path of the printer should be:
"\\SERVEUR_BDC\R&DHP4000TN"
Maybe, the printer name is too long, or the "&" is not correctly interpreted.
Kind Regards
Denis
(2,828 Views)
Hello Randy,
My network printer name is "R&DHP4000TN" and the printer server name is: "SERVEUR_BDC".
Maybe, the printer name is too long, or the "&" is not correctly interpreted?
What's your opinion about this ?
Kind Regards
Denis
(2,828 Views)
Denis,
I am not sure. Either one of them may be possible. The only way to find out is to rename the printer (if you can) and try it out.
Randy Hoskin
(2,828 Views)
