Labview 6.1 - invisible icons
Hello everybody
I got an update from NI to my Labview 6.0 to 6.1. I have spent 6
hours installing and deinstaling. After succesful installation
with all toolboxes and so on, my programs icins are not visible
at all!!!
I can open them, but I can not see the icons. I can see standard
icons and some of others but colorised icons are invisible. When
I try to add some vi the icon is vissible, but immediatelly after
I drop it to my vi, they disapear. What I shell do now. REinstall
once more to 6.0??
please give me some help.
thanks
PP
(2,805 Views)
I had the same problem. I could manage a workaround !
Goto to the Tools Menue and select Options.
Select at the topmost Pulldown-Menu "Frontpanel"
and disable the first point (it should be smoothing graphics or so ,
I cant tell you excactly cause I use the german version).
If you can find a better way please tell me!
P.S.: A Reinstallation didnt worked
cu
(2,805 Views)
Hi
Thanks for this, it sounds better than my solution with
decreasing the maximum color depth :).
regards
PP
Shodan wrote:
> Hi,
> cu
(2,805 Views)
OK, I got it, the colors in my graphics card has to be set at
65535, ufff....
PP
(2,805 Views)
