Labview 6 arbitrary function generator file format?
I have old hardware (e.g. DAQcard1200) which I have to use with old versions of Labview (4 or 6) (as they run on "old" hardware - Pentium1 embedded boards with Win98 etc.). With Labview 8 I can load a file in .lvm format and use it as output for A0. But how is this with the "arbitrary function generator" from Labview 6 (benchtop.llb)? I constructed an arbitrary function manually within the vi and saved it to a file, but its format does not make sense - only "strange" characters are displayed, like dŸ¾ “£¾ˆt÷¾ VJ¾– ¾ ñ¾£úD¾ªÛ˜¾±¼ë¾¸ž, if I open the file with an editor...
Thanks!!
😉 Torsten
(3,503 Views)
I don't have LabVIEW 6.1, but if the example hasn't changed, then that example writes out a binary file, which is why you get all those "strange" characters. The file should be an array of SGL values. Thus, you can read it into LabVIEW using the Read From Binary File, and wiring an SGL constant to the "data type" input.
(3,493 Views)
It seems that the file is a binary format. LabVIEW 6 is old and I don't have a copy. I also don't remember ever using benchtop.llb. could you just post it? From the diagram, it should be possible to see how the file write is being done and doing a file read should then be trivial.
(3,488 Views)
Thanks for the help, I should have looked myself in first place... The "Arbitrary Waveform Generator"  calls the "Write to SGL File.vi"...  I'm getting old... Well, hopefully I find my way to paste data from spreadsheets soon...
(3,482 Views)
