Labview 6
It's not about needing the LV6 disks.  You need your VI's that were originally saved in LV6.  You'll be able to open them in a newer version of LabVIEW.
Have you tried installing the LV6 runtime on your new PC?
Upconvert won't help you upconvert an .exe.  And you won't need the upconvert forum if you have the LV6 VI's and a newer version of LV.
And if you don't have your original VI's, then you really are SOL because without them you never can upgrade or modify your application.
Message 11 of 11
(389 Views)
