Labview 7.1 installation problem
Hi all-
I had to rebuild my machine and had to reinstall LabView.
Before the rebulid, everything with NI, DAQ cards and LV were running smoothly.
Now I have run into troubles upon re-installation of LabView.
First the specs:
Windows XP, SP2
3 NI cards: 6071E, 6602, 6503.
LV 7.1
NI-DAQ 6.9.3  (ancient, I know. I built software over the past 5 years that
interfaces to even more ancient electronics, so I'm forced into using these
versions.)
At any rate, my problem is that after I install LV, then the drivers, I do not see NI-DAQ VIs
appear in my LV functions palette.  I found the document online that says
to do LV first, then the drivers second (following the advise in:
(http://digital.ni.com/public.nsf/allkb/46E1672AB48C917D86256AFE00075436#DAQmx)
That is to say, when XP boots up, the little bubbles pop up saying "new PCI device detected."  I click cancel so that drivers are not installed until AFTER I install LV.  Then when I reboot, I install the drivers for all 3 cards listed above.
The cards are recognized OK, and I can see and configure them in MAX, just no functions on the palette were installed that correspond to these cards, such as AI-start.vi, DIO Port configure.vi, DIO write.vi, etc.
I tried reversing the order, drivers first, LV second, no luck.
I know it is possible to succeed, because I did this correctly once before 4
years ago.  But I can't figure out what is going wrong now.
A few last tidbits that might prove helpful:
 just to be clear: there are 3 CDs involved with this installation.
1. LV full development system 7.1 CD
2. Instrument Device Drivers CD
3. NI-DAQ software for windows xp (v 6.9.3) CD
When I am prompted for the device drivers disk, all goes well...I think.
When prompted to "select features to install" I selectr "Traditional NI
DAQ 7.0" and proceed.  I do not need DAQmx, so I don't choose to install it.
Any ideas what I am doing wrong/how to fix this?  I am probably missing something obvious.
NI people are such a knowledgeable bunch, and I'm sure we'll nip this in the bud no problem.
Cheers all-
jon
(3,915 Views)
Hi Jon,
I checked into your problem.  Your LabVIEW and DAQ versions are not compatible.  There are some extra steps you will have to follow to be able to use NI-DAQ 6.9.3 with LabVIEW 7.x or 8.x.
Ima
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
(3,880 Views)
Hi Ima,
Thanks for the response.
Since all my NI-cards (6071E, 6602, and 6503) were compatible with a later version of NI-DAQ, I went that route instead, installing NI-DAQ 7.4.4.
All is well now.
Thanks again.
(3,876 Views)
Hi Jon,
I am glad to hear that you are able to upgrade to NI-DAQ 7.4.4.  That is easier that trying to stay with 6.9.3.  7.4.4 is the latest version of the legacy DAQ driver and you should experience less problems with it.  I wish you the best in your application!
Ima
(3,869 Views)
