Labview 7.1 won't run under Windows 7
@LABorSi wrote:
I have many PC and until recently I haven't got much problem with installing Labview 7 into win 7 32bit.
Now probably the drivers have ben upgraded and installation is no longer possible.
I realised that LabViee itself is not problematic. Problems begin with installation of drivers (MAX).
Therefor I used third party visa librarries and it works
Well if it has worked before, then why didn't you use the driver versions from when it worked? Newer NI drivers don't support LabVIEW 7.1  (it may work but is not tested), since LabVIEW 7 is over 10 years old. If they would keep testing with every release of LabVIEW since 1992 then no drivers would ever be released anymore as the testing fixing and retesting would take to much time.
Basically if you have to touch a system with software that has been released more than 10 years ago, you will always be better of in not just touching it but also upgrading it to a more recent version. Yes it might be painful but so is trying to get to run old applications on Windows 7 or 8 and and especially getting the old drivers to support old hardware to run in these newer systems. Bascally a new DAQ board costs often less than 2 days of engineering time and that you can spend easily when trying to get old hardware and software to run in a modern PC.
The claim about needing to recertify an application if it gets upgraded doesn't really hold true either. Either it needs recertification on any form of touching such as when replacing hardware or the recertification claim is a more like a joke. So if it breaks down and you need to replace hardware (and OS) you better bite the bullet and upgrde the application too.
Rolf Kalbermatter  My Blog
Message 31 of 36
(3,236 Views)
Thanks.  It worked for me as well.  Nice to find this kind of support.  Thanks again.
Message 32 of 36
(3,187 Views)
Hii !
I  wanted to  open a programm that greatly runs under Labview 7.0 (on windows Xp ) with  the new version labview 10  on windows 7 but it doesent work .
A lot of error message indicating that there are  many miissing files .
Can anybody help me  to salve my problem ? Smiley Sad
Message 33 of 36
(2,975 Views)
Install the missing files? Really, you have not provided nearly enough information in order to help you. You should also start a new thread as your question does not seen related to this thread.
Message 34 of 36
(2,951 Views)
You probably want to start using actual versions of LabVIEW too.  It usually helps to provide non-imaginary information if you'd like to reach a non-imaginary solution.
Message 35 of 36
(2,935 Views)
it worked perfect , thanks(2022 windows 10)
Message 36 of 36
(2,281 Views)
