Labview 7 Application Builder
I have a problem with the Application builder in Labview 7.
I have a VI which uses the HTTP Server, i have built an apllication with the
VI as top level and the
HTTP server as a dynamic VI with all its necessary support files.
However when i run the Application the HTTP server starts and a dialog box
pops up which wants
the user to save a log file. This happens four times in a row, the Server
then starts and the application works fine. When openeing the log files they
are all empty i.e. no errors occour.
I have switched of error logging in the configuration file.
Any Suggestions
(2,661 Views)
Hmmmm...
A few more details might be a little more helpful... If you could write a scaled down version of your program that demonstrates the problem, that would be helpful for anyone trying to solve your problem.
I wish I could help you as I'm also doing some stuff with the HTTP server, but I'm just starting and don't have much experience with it.
One that comes to my mind is:
When is the webserver activated? You can programatically engage the webserver once your dynamic http vi is run, and disengage it when that VI is shut.
(This may have been the first thing you've tried and be thinking "thank you captain obvious" - in which case I apologize. Sometimes it's hard to judge the level of experience of the user from their posts. I reiterate that if you
provide a sample VI that can reproduce the problem, it could go a long way towards solving your problem)
(2,661 Views)
