Labview 7.* on XP Tablet system
Would a Labview Executable runing on Windows XP  Tablet PC Edition? with the IMAQ vision module functions?
How about the Labview DVE ?
(3,028 Views)
I've run LabVIEW 8 on an HP Tablet. It was a little slow, but did run with no problems.
Your main limitation is going be processor speed and memory. The HP I used has a P3 933 and 256M Ram.
 XP Tablet is really just XP with a few extras thrown in specifically for Tablet support/functions.
So you should be fine with LV 7.x as long as the Tablet specs meet the minimum requirments.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(3,020 Views)
You should aware that with XP Tablet SP2 you may encounter a problem in closing the application (but there are workarounds).
You can find more information here and in the related posts.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(3,017 Views)
