 spw
			spw
			08-24-2007 01:02 PM
 andre.buurman@c
			andre.buurman@c08-25-2007 08:43 AM
 mikeporter
			mikeporter
			08-25-2007 10:03 AM
 TreyB_NI
			TreyB_NI
			08-27-2007 10:13 AM
08-27-2007 11:43 AM
Thanks for all the responses.
I was using an existing VI as template to create a new program. There were nested loops in the original program and I needed the logic for the outter loops only for the new program. After deleting many objects in the 'yes' case in the inner loop, I was left with many loose wires in the 'no' case. And that's when my problem started, when I was trying to delete them. Yes, I tried rebooting my PC and that did not help. The problem seemed to get progressively worse, as crashing started to happen even when I was only selecting a wire. But somehow I was later able to select one wire, delete it, and did a save. Then I went to the next wire, and so on. My program is now cleaned up and I'm ready to go on. I will experiment more when the problem returns.
Thanks again.
