Labview 8.2 Installer
I'm rather new to both LabVIEW and to the forums, so apologies if I've done a less-than-ideal job of following etiquette. I've been tasked with updating some code written for LabVIEW 4 (Yeah, it's ancient), but I can't actually access any of the files with any currently available installation of LabVIEW. I found in this article (https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YSO4CAO&l=en-CA) that I should be able to use a version around LabVIEW 8.2 to bridge the gap. The current downloads on the NI page only go back to 2009, so I haven't had any luck there. Would anyone be able to provide a way to download the installer?
Thank you!
(2,080 Views)
Accepted by topic author argentsparq
To get access to any old LabVIEW installation you need an active SSP and reach out to NI Support for the such an old installer.
Santhosh
Soliton Technologies
(2,064 Views)
Ah, thank you. I'll give that a try. Have a nice day!
(2,048 Views)
good afternoon, were you able to figure out this problem, I have exactly the same and I don’t know how to solve it
(1,215 Views)
