Labview 8.2 can't write shared variable
Hi!
I developed LV 8.2 program using shared variable (network published) variant type. After extension of variable the vi charased after writing value in shared variable. If i changed shared variable from network published to single proces type the vi working OK.
(3,000 Views)
I have created a network published shared variable of type variant, and successfully written to and read from it.  Can you also post a snipet of your code which reproduces the problem?
General things to try in case include:
1. undeploy and redeploy the shared variable.
2. repair your LabVIEW installation - this will repair the variable engine, and I know of at least one case where this helped after it was corrupted.
I hope this helps!
Best Regards,
JLS
Best,
JLS
Sixclear
(2,965 Views)
