10-31-2007 06:09 PM
11-01-2007 03:24 AM
You cannot open VIs built upto 5.x dorectly in LV 8.x. You ve to convert them to an intermediate version like 6.x or 7.x to make them openable in LV 8.x.
See the below threads also.
http://forums.ni.com/ni/board/message?board.id=170&message.id=280863#M280863
http://digital.ni.com/public.nsf/allkb/429E45271CFD683786256D87006B1EEF
11-01-2007 11:09 AM
Partha,
That's not quite correct. It is only LabVIEW 8.5 that does not allow you to open a 5.x VI. It should open in 8.2.1.
Mike,
It has been a very long time since I've looked at the test executive VIs. Can you open any of the subVIs? If the problem can be isolated to one of those it might help to figure out what is wrong.
11-01-2007 01:09 PM
Dennis,
Thanks for the response. The odd thing is that I am able to open some of the subvi's. And I've opened the test executive before. Now, during the initial loading of the Test Executive, there are some drivers that are not executable by Labview 8.2.1 (i.e. ni-daq cards.... for MIO and DIO boards). Could that be it? I would expect the program to load but not run. I have gotten the program to load before, so I am confused by it not loading now. Thanks for the tip on Labview 8.5 as I was ultimately going to that version, too!
My ideal situation would be to load all drivers ( including Traditional Ni-daq and Ni-VXI 3.3.1, etc) and run this program using Labview 8.5 or 8.2.1 on an XP platform. This original program was created in Labview 5.1 and Windows NT. Any help and suggestions would be appreciated.
Thanks for your help,
Michael
11-01-2007 10:28 PM
