Labview 8.5 Slow
OK, here's a quick solution that does it with linear interpolation in under 30ms. See if it works for you. 🙂
The secret is in the feedback node, which is allowed because the xi-array is sorted. 😉
Message 21 of 23
(876 Views)
Thank you all for your comments.
altenbach: the workaround OrderAnalysis-2aInterpolacion_revCAFast.vi works fast enought for me Smiley Very Happy
However, what you and also other did was to made the code more efficient (something that I should also try to do!), so that it run faster. But from the LV version point of view I still don't understand the difference of execution time.
once again, thank you all
Message 22 of 23
(845 Views)
Using built in functions and more concise code will make it run faster. If you have your older code and the new one, it will be easy to compare and see why the new is running slower than the older one. But its going to be difficult otherwise. Hopefully, all the feedback in this forum has helped you figure out a code thats as good as your old one.
Warm regards,
Karunya R
Message 23 of 23
(813 Views)
