Labview 8.5 crash frequently
MONTIX wrote:
Hey check your configuration for your workstation,it may not be able to process that much calculations.
Adding two numbers!  LOL!!!  😄   That's a funny one!  😄  (you were kidding, right? 😉 )
I am slowly migrating to non-ms-os machines.  I agree that Linux offers more control over... well... everything..  but it is not for the novice..  although an excellent learning experience.  🙂
Message 11 of 16
(958 Views)
I tried your suggestions, It didn't help.
Message 12 of 16
(955 Views)
You mean it still crashes? 😮
Can you post the code?  Use the browse button below "Attachment" under the message edit box to browse and select the vi.
Message 13 of 16
(944 Views)
I found the problem. I had a wrong definition of probe at  C:\Documents and Settings\Gabi\My Documents\LabVIEW Data\Probes
I delete all the probes in the above path and the problem was solved.
Message 14 of 16
(925 Views)
Message 15 of 16
(924 Views)
Glad to read you found the problem and thanks for sharing!  🙂
It's quite interesting that these behaviors could be anything..  That's why it's best not to re-install LV right away.  Finding the root cause may help avoid headaches in the future.  I must admit that I would not have thought of custom probes..  🙂
Message 16 of 16
(913 Views)
