Labview 8.5 on Windows Vista
Hello
Is Labview 8.5 compatible with Windows Vista??? Also will I have problems with the device drivers and DAQ-mx? I am using NI-USB6008.
(3,582 Views)
.... sorry I have Labview 8.6 which I would like to install on a Vista computer.
(3,573 Views)
Which version of Windows Vista are you using? 32 bit, 64 bit, Home, professional? Did you do a search on the National Instruments site?
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,565 Views)
Accepted by topic author lav21
Did you try a search? This question has been asked an umpteen number of times. No, wait, don't bother, let me type the words in the search bar for you...
Windows Version Compatibility with LabVIEW
NI-DAQ and LabVIEW Version Compatibility (for Windows)
EDIT: I see LV_Pro had already posted the same answer.
(3,558 Views)
Thanks to both!
(3,534 Views)
