Labview 8.6 driver support for PXI6071E multifunction IO card
I have PXI6071E multifunction IO card with PXI 8176 controller. I used LabView 7.0, RT 7 and DAQ traditional, i could get remote connection with all device visible in MAX.
Presently i tried LabView 8.6 and DAQmx8.9, for above configuration, i could have PXI chassis in MAX remote PXI, but i can not see PXI 6071E device in remote PXI.
Is it any body know that can i use PXI6071E with LV8.6. or have to use older version only? Or still i have to install some things else?
--Vishnu
(2,807 Views)
Accepted by topic author Vkumar
Hi Vishnu,
Good afternoon and I hope your well today. Thanks for the post!
I believe LabVIEW 8.6 is supported by DAQmx 8.9. And that DAQmx 8.9 supports the PXI6071E.
Firstly, I would make sure that you've installed DAQmx onto the target, and included supported for LabVIEW. I would also ensure this installation was done last, you must install software, modules, then drivers. I would maybe suggest reinstalling the DAQmx driver.
Installing Software on Real-Time (RT) Series PXI Hardware
http://digital.ni.com/public.nsf/allkb/D170D1AF82303EA086256B4200780579
Are any other cards seen? Maybe suggest another slot if possible. But I'd suggest checking the installation first.
Hope this helps,
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(2,796 Views)
Thanks James,
I installed all software and then installed driver, it works.
Thanks.
--Vishnu
(2,762 Views)
Hi Vishnu,
Good Morning and I hope your well today.
Thanks for the post and the update.
I am glad its all working for you. Please mark as answered and consider the kudos click 🙂
See you again on the forum soon!
Kind Regards
James Hillman
(2,760 Views)
