Labview 8 error/bug?
Hello
Probably already well known. File attached. Add a Shift register to a while loop and wiring the left SR node to a constant. The switching between replace SR with Tunnel, and vice versa leaves a black tunnel or an extra tunnel and a  miswiring. Broken error arrow, but error dialog shows no error message. This eoor was first posted in the LAVA group, but my addition was to try switching back and forth and finding how this tunnel and miswiring multiplies.
Khan
(4,866 Views)
Yes, this looks like a bug. Intrestingly, I have never encountered it until now....
(4,856 Views)
Hello kkabir,
This has been reported to engineering (# 3S46D75L) for further investigation. In order to alleviate the broken arrow, you can delete the unwired tunnel on the right side of the loop, as i'm sure you've already noticed.  Thanks for the feedback!
Wendy L
LabWindows/CVI Developer Newsletter
(4,824 Views)
This was reported to R&D (# 3S46D75L) and was fixed in LabVIEW 8.2. Here is a link to the current evaluation software download for LabVIEW.
Thanks!
Travis H.
LabVIEW R&D
(4,655 Views)
