Labview 8: prim.cpp Fatal Error
Everytime i click Start>Labview 8 Labview crashed with the following message:
Fatal Internal Error: "prim.cpp", 4576
I cant get any work done- Labview will NOT run!
Anyone have any suggestions????
(2,651 Views)
One thing that I would suggest if you can't even launch LabVIEW would be to try to repair the installation of LabVIEW.  If you select Add/Remove Programs from the Control Panel, and select National Instruments Software and new dialog should pop up.  Select LabVIEW 8 and then click repair.  It will ask you for the resources that you used to install LabVIEW ( ie. the CD), so make sure you have that available.  If that doesn't work then I might suggest uninstalling it and then reinstalling.  After uninstalling and before reinstalling, copy the CD if you have one to your hard drive and install from there, just to make sure that this isn't causing an issue.  Repost if you have any problems!
Thanks!
Andy F.
(2,641 Views)
And... the LabVIEW update to version 8.0.1 is now available on the website. Quite the list of fixes. Give that a try as well.
     Rob
(2,633 Views)
